I really like DipTrace.
.MeLee
04-04-2013 #2
Check out visolate which is quite good, the page has a lot of other useful stuff to.
http://reprap.org/wiki/PCB_Milling#g...cb_-.3E_G-codeIf the nagging gets really bad......Get a bigger shed:naughty:
04-04-2013 #3
wrt to pcb milling, I thought visolate would be by saviour...(I spent way too long trying to master it) ...it turns out it was my curse.
Using voronoi regions sounds like an excellent way of cutting down on track cutting (track isolation) time...turns out it's also an even better way if increasing the stray capacitance on your final pcbs (not by a little...by a *massive* amount)Last edited by HankMcSpank; 04-04-2013 at 09:04 PM.
04-04-2013 #4
I would agree with you on that Hank. To have a go at routing pcb's though is a good way to practice with software wise though.
04-04-2013 #5
I'd say designing PCBs is not massively complicated if it's for simple circuits, where placements of elements is not that crucial. I've used EagleCAD before and got my head around it pretty quickly.
As far as cutting goes, I would've loved to have a CNC simply to cut the acid etched PCB down to the right size, especially when doing round shapes. Then again, if you can auto generate the g-code, I guess there's no quicker way. Just for laughs and to show acid etching works not so badly, here's a PIC based timer board I've done a long time ago:
this is the round PCB which could've used a CNC.
Regards,
dsc.Last edited by dsc; 04-04-2013 at 10:03 PM.
04-04-2013 #6
Wow thanks guys .. loads of advice there and ideas :) .. what do think of this and dont start with "Fuckin Maplins are crap" lol but they have a starter kit half price its looks like print iron and disolve.. thinks its wortha tenner punt to havea go ?
Ralph Waldo Emerson
04-04-2013 #7
I'd say Maplins are crap, but it's where I got sodium persulphate which I couldn't get anywhere else. To make your board you need that, an iron, a blank PCB and ink printer. As always google is your friend.
That kit says etchant material, although doesn't specify what it is. Then again for a tenner, might be worth a try.
Regards,
dsc.
gerber to dxf for PCBs
By Web Goblin in forum Computer SoftwareReplies: 4Last Post: 26-10-2013, 08:25 PM -
Where to get PCBs made in reasonable quantities?
By Jonathan in forum General ElectronicsReplies: 7Last Post: 07-09-2013, 05:25 PM -
NEW MEMBER: PCBs - desktop CNC - Hi from salisbury
By Plod in forum New Member IntroductionsReplies: 10Last Post: 07-09-2013, 09:34 AM -
RFQ: Why is it so hard...
By ktc in forum Projects, Jobs & RequestsReplies: 10Last Post: 11-08-2013, 08:05 PM -
Make your own Super- PID ... not that hard to make ! .... says electronics genius!
By Buba b in forum General ElectronicsReplies: 4Last Post: 26-04-2013, 08:37 AM
